Switch between views
All  1-3  4-8
8027.4
Hi Nick
here is a script that you can save as a shortcut key, I use the "space" key that will maximise whichever view the mouse pointer is over
its a very fast way to get the view you want 2nd press on space sends the view back to all 4 .
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) { viewport.viewPanel.mode = viewport.name } }
cheers
shayne
8027.5 In reply to 8027.4
Ah thanks a lot Shayne, that's very useful!
8027.6
Reviving this old thread, to ask if there's a command or script to toggle a view under the mouse pointer to the opposite view?
So if my pointer is over a top view (either full screen or a quad view) and I activate the command or script, the view will switch to the bottom view.
Thanks in advance!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
8027.7 In reply to 8027.6
8027.8 In reply to 8027.7
Exactly what I meant, thanks for the always swift reply, Michael!
─ Metin
Show messages: All  1-3  4-8
