Double sweep
All  1-3  4-11
8020.4 In reply to 8020.3
Thanks I just went back and reworked the Moi sweep tool and it worked great!
Size: 62.8 KB, Downloaded: 31 times, Dimensions: 513x774px
8020.5 In reply to 8020.4
Better illustration of what I am doing. For future reference, technically which are the rails and which are the profiles?
See new attachment.
Size: 112.7 KB, Downloaded: 62 times, Dimensions: 918x834px
8020.6 In reply to 8020.5
Hi Mike, usually the long vertical ones would be used as the rails.
> In Rhino they term it Sweep 2
It sounds like you've got it figured out already, but just in case - in MoI both of Rhino's "Sweep1" and "Sweep2" commands are combined in a single Sweep command, which will do a "Sweep1" if you select just one rail at the rail picking stage, or "Sweep2" if you select 2 rails at the rail picking stage. If you select 3 or more rails MoI will do a sweep1 along each of them.
You can also use Construct > Network on a curve setup like that as well.
8020.7 In reply to 8020.5
But they are interchangeable if Rails < 3 & Profiles < 3! :)
So not here! 5 & 2 !
EDITED: 9 Jul 2016 by PILOU
8020.8 In reply to 8020.7
Hi Pilou, they aren't interchangeable for the sweep command, because you can have either one or two rails for the sweep command, and any number of profiles. So in that case where there are 5 curves in that one direction, those have to be the profiles not the rails.
8020.9 In reply to 8020.8
Thanks for the precision!
8020.10
Excellent help as always. The bottle I was creating was for the Ragu Homestyle pasta sauce. Thanks Again!
8020.11 In reply to 8020.8
Show messages: All  1-3  4-11
