Would like to try demo again and not receiving any reply to emails
8001.1
Hi all,
I was in email correspondence with MoI support about getting another go on the demo version, I was given an alternative demo download, however it still gives me the message that the 30 day download limit has expired. I have emailed this information 3 times to support and not received any further reply, I'm a little annoyed that I'm having to go to these lengths to receive help It's quite possible I've found something that MoI can do better than other software we use and as a result we may buy 1-3 copies, but I need to see if it works first of all. I would appreciate some help here.
Martin
8001.2 In reply to 8001.1
My experience with MOI support has been exceptionally good so far (indeed the best experience ever
with software-companies) , so I am sure you will get help soon !
8001.3 In reply to 8001.1
Hi Martin, sorry I do not seem to have received your later messages, possibly they have been intercepted by the spam filtering service.
Is it possible that the date on your machine has been changed recently? If so then that can cause the 30-day trial versions to expire prematurely. Or maybe there is some other problem like your virus checker is interfering with things. At any rate I'm sorry but if the second trial that I sent to you is also expired I don't have any way set up to do a 3rd one, you would need to try installing the 30-day trial version on some other machine or if you want to test modeling things instead of exporting you could use the "no save" trial version for testing modeling workflow, it's available a little bit lower down on the downloads page.
8001.4 In reply to 8001.3
Hi Michael, no problem, thanks for your help - Is it possible to export using the 'no-save' trial version?
8001.5 In reply to 8001.4
Sorry no! But you can Import!
8001.6 In reply to 8001.4
Hi Martin,
Sorry no - the no-save trial version does not ever expire but also does not have any type of file exporting enabled. You can use it to test modeling workflows primarily.
To test exporting you need to use the 30-day trial version but unfortunately you will need to install that on a different computer if both trials are expired on your regular one. Also take care not to modify your system date while doing the 30-day trial as that will mess it up and can cause it to expire prematurely.
8001.7
Thank you both for your help, I'll see if I can get it on another computer
