Save as including screenshot
All  1-2  3-7
7998.3 In reply to 7998.2
>> // config: norepeat
moi.geometryDatabase.saveAs( moi.command.getCommandLineParams() );
script:var img = moi.view.screenshot( 'viewpanel', false ); var filename = moi.geometryDatabase.currentFileName; if ( filename != '' ) { img.save( filename.substring(0,filename.length-3) + 'jpg' ); } >>
Should I paste the whole text into the shortcut menu ? I tried it but does not work this way for me
EDITED: 21 Jun 2016 by SIRTOM
7998.4 In reply to 7998.3
Thats not a script, it's a command. Put it in a js file with a name. The name goes in a shortcut area. (Without the dot js part)
7998.5 In reply to 7998.4
Thankyou Burrman great tip - it works perfectly now !
7998.6
Hi
If you save it into the save.js
when you save your file it will also save the jpg with it as below
For saveas.js change the save() to saveas()
/// config: norepeat
moi.geometryDatabase.save();
cheers
shayne
7998.7 In reply to 7998.6
Good to know - thanks !
Show messages: All  1-2  3-7
