View points won't switch
7995.1
I haven't used MoI recently but when I was previously using it just after V3 came out it was working fine.
Now when I use it the 4 different angles you can view the grid at don't change when I select the different views from the bottom bar.
The only one that i can change to is the 'right' angle the rest don't respond.
Not quite sure why this is happening, is there a way just to do a clean install, or any suggestions to resolve the issue?
7995.2
Does anyone have any idea? MoI is unusable whilst its like this.
Message 7995.3 deleted 19 Jun 2016 by BEMFARMER
7995.4 In reply to 7995.1
Hi Jacob, my guess is that you're running MoI version 3.0 on Mac and you've updated your operating system to El Capitan?
Apple has changed some things that broke various things in MoI, one of which is the view switching like you describe.
You can get it fixed by downloading the newer MoI version 3.1 release which has changes in it to solve those problems, you can get it by putting in your V3 license key here: http://moi3d.com/reinstall.htm
7995.5 In reply to 7995.4
Thats great, thank you very much for your help.
