Select by Surface minimum Size?
7990.1
I have subjected an array of surfaces to a Boolean intersect against a closed curve.
Only the intact surfaces that were fully within the close curve are of interest.
Is there some way to automate the selection of the partial surfaces (those that were actually cut by the closed curve) that now exist around the periphery?
-- Mindset
7990.2 In reply to 7990.1
Hi Mindset, there is a script here which will select things based on the length of the bounding box diagonal:
http://kyticka.webzdarma.cz/3d/moi/#SelectTiny
That's probably the closest to what you're describing.
7990.3
Terrific Michael,
I wish I could give a Nobel Prize myself.
Follow-on question:
Is there a way to use a closed curve as a marque selection tool??
Thank you SO VERY MUCH!!!
7990.4 In reply to 7990.3
Hi Mindset,
> Follow-on question:
Sorry no there isn't any way set up to do that currently.
