Live preview not working
7987.1
Hi there,
I have the following problem: Sometimes, it seems only with heavy scenes, MoI doesn't live-preview geometry that's being altered at that moment. Regarding this example: Only the 3d object is constantly re-drawn in the 3d viewport when being moved, but not the 2d lines preview. Why is that?
7987.2 In reply to 7987.1
Hi 3image, that's a feature to improve performance while dragging a complex object. The edge display tends to take the most time to display and when you drag an object that has over a certain threshold number of faces, it will use a special lightweight drawing mechanism to keep the display going at interactive speeds.
The threshold value can be modified in moi.ini under this location:
[Transform]
ProxyGenerationNumFaces=50
The default is to enable the quick drawing mode when transforming an object made up of 50 or more faces.
7987.3 In reply to 7987.2
Now it works. Didn't know of that setting.
Thank you so much, Michael! :-)
