How to model
All  1-5  6-19
Maciek -
I tried the approach of sweeping profile curves around a closed wristband curve.
The orange watch is a rectangular box with fillets.
The orange watch can be boolean diff with the watch band to cut away the unwanted portion of the band.
7984.7
Hello Guys,
Thank you so much for showing me different directions.
Anyhow it is not exactly what I need.
The part of the strap needs to be exactly shaped like apple watch side. Its like cutout from alu part of the body with the same curve (ORANGE).
I know I am quite close but still I am not able to smooth the edge I marked as (RED), so probably my approach is still wrong.
I tried also with boolens (first I projected curve so its a propare base for loft) but It gave me also something weird artifacts.Cut was not completly smooth.
ANd this is manual adjustemnt work with points so probably no go for proper Nurbs modeling.
I don't give up but I am sure there is 100% accurate and better way to do it :)
BEst
Maciek
EDITED: 14 Jun 2016 by PTASZEK
Hi Maciek -
Using your 3DM file, I trimmed the wrist band rail further back from the ring, and used just two profile curves to sweep the band.
I selected the edges that make up the opening in the watch and converted into a closed curve, and left in place.
I made of copy of this curve and moved it away from the watch. I then flattened this curve and resized it slightly smaller in width.
I made a copy of the profile curve at the end of the sweep and positioned it away from the end of the sweep.
I mirrored the four curves to the opposite side.
I selected these four curves and made a Loft. The two curves between the sweep and the watch are "helpers" to guide the shape of the loft as needed.
Looks like I'm all out of forum free space to upload the 3DM file :( That's what happens when you upload monster sized tutorials :)
Regards -
7984.9 In reply to 7984.8
Hello Ed,
Thank you for the small tutorial :)
I know I am too picky but this is the reason why I would like to switch from poly to nurbs.
I would like to have perfect shape there.
I tried your method and I had same issue like you.
The weird dent (marked as BLUE) and the curve is not going as precise at it should - more curved and the end of strap is exactly same shape as watch part (marked as RED).
Please check the reference picture. It is really pain in the ass for me :) I am trying it for 15-20 h.
Best
Maciek
Maciek -
I see that the strap flattens and adapts to the shape of the watch at the ends.
I would add more "helper" profiles that mimic the watch profile (top view) to try to force the loft to conform as needed.
Because "History" is enabled for Loft, you can move and resize your profile curves while watching the Loft automatically update.
This is a tedious method to be sure, but as Michael stated, it's more of an organic shape not easily made in NURBs.
7984.11 In reply to 7984.10
Yes you right,
with precise profiles it doesnt fit 100% and with manual adjustments its not 100% precise ;)
Anyway I dont give up yet ;) its a good nurbs lesson for me :)
btw what do you think about the watch itself? Did I make some huge mistakes there?
Best
Maciek
7984.12 In reply to 7984.7
Hi Maicek
It might be worth looking at this video on variable filet. https://www.youtube.com/watch?v=CemIL-wleOw
I have been playing with your file and have come close and I think I could succeed but other things in life need doing.
Having said that Ed is a better modeller than I so it might be best to follow his advice:)
Keith
Maciek -
This is the best result I can get. It uses 5 profile curves to build the Loft.
I emailed the 3DM file to you as I'm out of allocated space for posting attachments to the forum.
Also, to best evaluate your model, make a render. Sometimes in the MoI display things may not look perfectly smooth, but when you render all is good.
Regards,
EDITED: 12 Jun 2016 by EDDYF
7984.14
Hello Ed,
thank you for your email and help :)
I did it in similar way (pls check the email)
Last questio nis if its possible to close the strap inside the watch (marked as GREEN)
I place it also here cos maybe someone wants to see it :)
Best
Maciek
Maciek -
Filling the gap in the band -
Making extensions and capping off after the fact can be difficult, if not impossible, on complex objects. It's best to avoid making patch work by making the object larger than needed, then cutting away what is not needed.
I would delete the Loft and add one more profile curve (planar) inside the watch. That way you are making the band longer than needed. Try making this new profile curve a copy of the curve that conforms to the watch opening, flatten it using the selection handles (to make it planar), and stretch it a little taller, and wider than the watch. Adjust this curve so the areas that intersect the watch conform to the watch opening.
The resulting Loft should be be a solid because each end is planar.
Now you can create a cutting curve in whatever shape is needed to Boolean away the unwanted band section just inside the watch. The result after the Boolean should remain a solid.
It may be that the band does not conform exactly to the watch opening. If so, you could take a version of the watch that has no opening, and use the watch band to create the opening via Boolean Diff.
How accurate you need to be depends on your application. It's really difficult to try to replicate complex semi-organic objects to exactly match a blueprint.
7984.16 In reply to 7984.15
Maciek -
Here is an idea if you want to fill in the band (But better to make it all from the beginning rather than fill in)
7984.17 In reply to 7984.16
Hi Maciek - yes like Ed writes above usually you don't want to be trying to fill in an empty surface to cap something like that - if you're doing that again it usually means you're trying to build things in a "patch by patch" manner rather than using solids and booleans. With NURBS modeling you would usually get that type of cap by slicing the end of a solid off with a 2D side profile curve, that will leave the imprint of the extruded side profile as the cap.
NURBS modeling may not be the right tool for this purpose though - again as I wrote above NURBS modeling works best when you are able to describe the shape using 2D profile curves.
If the shape needs to be adjusted by a kind of sculpting approach with adjusting the shaping in some very local area, then that usually becomes more related to organic modeling where polygon modeling can work better since polygon modeling can get you that type of fine tuned local sculptural control.
So anyway since you're not working with 2D profile curves or solids very much and since you're also concerned very much with subtle shaping characteristics in a localized area of a surface, it's entirely possible that NURBS won't be the best fit for your needs, or it also may be possible that you'll need to work with the more finicky and advanced type of NURBS surface shaping which MoI is not focused on itself. You may need to take a couple of years of study with Rhino or Alias for example to do that type of thing.
7984.18 In reply to 7984.14
Here's how the connection would be made (no focus on the shape of the watch)......
What you want to do is model the watch body and band as a solid in a flat plane. then flow that to a band curve, then cut the connection of the band and body with a single curve from a side view....
7984.19 In reply to 7984.18
Here's another one where I used the "side cut" but then used a sweep to create the band (Sweeping a regular band shape along a curve to meet the face of the side profile cut)... Looking at the underside of the band, I didn't control that well through the sweep, so it messes with the aesthetics of the side profile view. I was going to look at a scaling rail to control this part, but kindof had enough already. Also, someone else showed how to just create multiple profiles along the path using loft, which would do the same to fix the sweep also...
Also, the original side cut is where you get the shape of the end of the wrist band. After I created that and used it to create the band fitted to the body, I deleted the original side cut out of the body, then did a funky blend cap on the end of the band and re-cut that out of the body. It maintained the original profile intent but created a cool organic cavity on the body... I guess it depends on how you want the guts of the body and the band to be connected. I don't have an apple watch.
Anyway,
Show messages: All  1-5  6-19
