How to model
All  1-13  14-19
7984.14
Hello Ed,
thank you for your email and help :)
I did it in similar way (pls check the email)
Last questio nis if its possible to close the strap inside the watch (marked as GREEN)
I place it also here cos maybe someone wants to see it :)
Best
Maciek
Maciek -
Filling the gap in the band -
Making extensions and capping off after the fact can be difficult, if not impossible, on complex objects. It's best to avoid making patch work by making the object larger than needed, then cutting away what is not needed.
I would delete the Loft and add one more profile curve (planar) inside the watch. That way you are making the band longer than needed. Try making this new profile curve a copy of the curve that conforms to the watch opening, flatten it using the selection handles (to make it planar), and stretch it a little taller, and wider than the watch. Adjust this curve so the areas that intersect the watch conform to the watch opening.
The resulting Loft should be be a solid because each end is planar.
Now you can create a cutting curve in whatever shape is needed to Boolean away the unwanted band section just inside the watch. The result after the Boolean should remain a solid.
It may be that the band does not conform exactly to the watch opening. If so, you could take a version of the watch that has no opening, and use the watch band to create the opening via Boolean Diff.
How accurate you need to be depends on your application. It's really difficult to try to replicate complex semi-organic objects to exactly match a blueprint.
7984.16 In reply to 7984.15
Maciek -
Here is an idea if you want to fill in the band (But better to make it all from the beginning rather than fill in)
7984.17 In reply to 7984.16
Hi Maciek - yes like Ed writes above usually you don't want to be trying to fill in an empty surface to cap something like that - if you're doing that again it usually means you're trying to build things in a "patch by patch" manner rather than using solids and booleans. With NURBS modeling you would usually get that type of cap by slicing the end of a solid off with a 2D side profile curve, that will leave the imprint of the extruded side profile as the cap.
> I know I am too picky but this is the reason why I would like to switch from poly to nurbs.
> I would like to have perfect shape there.
NURBS modeling may not be the right tool for this purpose though - again as I wrote above NURBS modeling works best when you are able to describe the shape using 2D profile curves.
If the shape needs to be adjusted by a kind of sculpting approach with adjusting the shaping in some very local area, then that usually becomes more related to organic modeling where polygon modeling can work better since polygon modeling can get you that type of fine tuned local sculptural control.
So anyway since you're not working with 2D profile curves or solids very much and since you're also concerned very much with subtle shaping characteristics in a localized area of a surface, it's entirely possible that NURBS won't be the best fit for your needs, or it also may be possible that you'll need to work with the more finicky and advanced type of NURBS surface shaping which MoI is not focused on itself. You may need to take a couple of years of study with Rhino or Alias for example to do that type of thing.
7984.18 In reply to 7984.14
Here's how the connection would be made (no focus on the shape of the watch)......
What you want to do is model the watch body and band as a solid in a flat plane. then flow that to a band curve, then cut the connection of the band and body with a single curve from a side view....
7984.19 In reply to 7984.18
Here's another one where I used the "side cut" but then used a sweep to create the band (Sweeping a regular band shape along a curve to meet the face of the side profile cut)... Looking at the underside of the band, I didn't control that well through the sweep, so it messes with the aesthetics of the side profile view. I was going to look at a scaling rail to control this part, but kindof had enough already. Also, someone else showed how to just create multiple profiles along the path using loft, which would do the same to fix the sweep also...
Also, the original side cut is where you get the shape of the end of the wrist band. After I created that and used it to create the band fitted to the body, I deleted the original side cut out of the body, then did a funky blend cap on the end of the band and re-cut that out of the body. It maintained the original profile intent but created a cool organic cavity on the body... I guess it depends on how you want the guts of the body and the band to be connected. I don't have an apple watch.
Anyway,
Show messages: All  1-13  14-19
