Flow Letters Around Wedding Band
All  1-8  9-16
7980.9 In reply to 7980.8
Hi shayne, no unfortunately it's not possible currently to get history update working on array commands. History is not stored for those particular commands because it was causing large bloated file sizes to store all inputs for the array on each generated instance.
In the future I do expect to change the history function to work more like a log of actions rather than being attached to each object. But there will be a lot of work involved in doing that so I'm not sure when it will happen.
7980.10 In reply to 7980.9
From the point of view of a software developer, i must admit that i really appreciate your way
to elegantly disenchant the users' wishes.
Ciao!
Marco (mkdm).
7980.11 In reply to 7980.10
Thanks Marco! :)
7980.12
Thanks Michael
I regret some things in life are not possible :( but one can but dream :)
I use Moi everyday to manufacture jewellery and its brilliant
Thank you and the forum for all your help over the years
shayne
EDITED: 8 Jun 2016 by SHAYNO
True gem! ;)
7980.14 In reply to 7980.12
Hi shayne, your ring is lovely!
7980.15 In reply to 7980.14
Thanks Michael
my saveas.js has the following to save a jpg with the save
can this be changed to just save the 3d view only
thanks
shayne
// config: norepeat
moi.geometryDatabase.saveAs( moi.command.getCommandLineParams() );
script:var img = moi.view.screenshot( 'viewpanel', false ); var filename = moi.geometryDatabase.currentFileName; if ( filename != '' ) { img.save( filename.substring(0,filename.length-3) + 'jpg' ); }
7980.16 In reply to 7980.15
Hi shayne,
Try changing your current parameter 'viewpanel' to instead be '3D' . Then if you're in split view mode it should target the 3D view. If you're in a maximized view mode it will behave the same as 'viewpanel' though.
Show messages: All  1-8  9-16
