Flow Letters Around Wedding Band
All  1-12  13-16
True gem! ;)
7980.14 In reply to 7980.12
Hi shayne, your ring is lovely!
7980.15 In reply to 7980.14
Thanks Michael
my saveas.js has the following to save a jpg with the save
can this be changed to just save the 3d view only
thanks
shayne
// config: norepeat
moi.geometryDatabase.saveAs( moi.command.getCommandLineParams() );
script:var img = moi.view.screenshot( 'viewpanel', false ); var filename = moi.geometryDatabase.currentFileName; if ( filename != '' ) { img.save( filename.substring(0,filename.length-3) + 'jpg' ); }
7980.16 In reply to 7980.15
Hi shayne,
Try changing your current parameter 'viewpanel' to instead be '3D' . Then if you're in split view mode it should target the 3D view. If you're in a maximized view mode it will behave the same as 'viewpanel' though.
Show messages: All  1-12  13-16
