project moi3d v4
 1-13  14-33  34-53  54-73  …  94-98
7954.14 In reply to 7954.3
Hi Michael
Regarding V4 rewrite one thing that might be useful if its possible is a countdown bar for processing command calculations
I am pushing MOI sometimes with complex sculptural forms and I do not know if its going to takes seconds or hours to process a command - if it estimates hours I would abort immediately but minutes I might wait
Fantastic software by the way
Andy T
7954.15 In reply to 7954.14
Hi Andy, re: countdown bar - unfortunately it's very difficult to estimate the amount of calculation needed for many operations. Often times CAD calculations work by a kind of iterative refinement approach where an intersection or solution starts out rough and then is refined with additional passes until the result is within tolerance. With this kind of "iterate until within tolerance" operation it's very difficult to estimate before hand how many iterations will be required.
So unfortunately , it's not likely to be technically possible to give the kind of estimate you're looking for on every command. I do want to add a progress bar for file imports though.
7954.16 In reply to 7954.15
Hi Micheal,
Could you give us a heads up on how's the work going for V4?
Marc
7954.17 In reply to 7954.16
Hi Marc, I've been making good progress recently, more and more systems getting functional. A couple of the biggest areas left to do are the viewport display engine and then figuring out if I'm going to be able to switch to a different geometry kernel for v4.
But things are starting to get a bit easier to port over because more of the building blocks are in place.
7954.18 In reply to 7954.17
Hi Michael, there must not be a thousand options for geometry kernels, it was Solids++ in Moi right?
Would switching involve more coding ? I imagine the routines would differ ?
Marc
7954.19 In reply to 7954.18
Hi Marc,
Yup, that's correct.
Yes, everything is similar in general principle but the specifics are all different and so there's a lot of work involved.
7954.20 In reply to 7954.17
"""""""Switch modeling kernels"""""""
Oooooooooooo. ACIS!!!!!
What an huge jump to go x64 AND modeling kernel...
But the fillets! :o
7954.21 In reply to 7954.20
Hi Burr, I'm not sure if it will happen for v4 or not yet, but I will be spending a chunk of time seeing how much work will be involved. It's not ACIS though - it's called KCM. It's possible that I might try doing it in stages, like doing filleting and shelling with it.
Don't get too overly excited quite yet though - I can't promise that it will happen for v4 yet.
7954.22 In reply to 7954.21
Righto..... Onward!
7954.23 In reply to 7954.21
Hi Michael, did you check out this GK, from the Ascon Group, https://en.wikipedia.org/wiki/C3D?
See here, too: https://en.wikipedia.org/wiki/Geometric_modeling_kernel
Best,
Diego
7954.24 In reply to 7954.23
Hi Diego, yes I've read some about that one too, and I have seen that wikipedia page before as well.
7954.25
So it seems, that the first beta v4 comes closer.
7954.26 In reply to 7954.23
C3D release date? 1995!!!
7954.27 In reply to 7954.26
Yep, their "Initial" release date ;) What's cool about this, IMO, is it includes within it a geometric-constraints engine - they call it "Solver", taking care of managing relative positions, angles and distances between 2 and 3D objects - at least for those interested in such matters.
Best, Diego
7954.28 In reply to 7954.21
Hm, if this is the one you are talking about, the website now says they are ceasing development of KCM.
http://www.kcm3d.com/
7954.29 In reply to 7954.28
Hi Dan, well that's news to me... I'll send off an e-mail and ask what's going on.
7954.30 In reply to 7954.28
Hi Dan, so everything's still ok with KCM, the website doesn't go into all the details.
7954.31
Hello,
http://www.plmconnections.com/feature_article.php?read=1&g=183a1a39-0017-11e6-a26a-d4ae52bb7f09&cpfeatureid=116192&page=all
I have my theories on this but they are simply that.
What I do know is that it would be really neat to see MoI run on a newly minted platform like KCM that is not held back by decades old technology and workarounds.
7954.32 In reply to 7954.30
Hi Michael....
I am afraid using a kernel engine that not under active development will sacrifice the future of MOI. Why not Acis, parasolid or C3D Geometric Kernel? As far as I know those 3 are the only good one. Please consider it carefully. .....
Just my thought. ...
_Anis
7954.33 In reply to 7954.32
Hi Anis, KCM is under very active development. ACIS and Parasolid are limited and fussy in many ways, they have an old code base and have many limitations. Parasolid for example has very stringent requirements on how accurate geometry has to be in order for it to be accepted by the kernel. That may sound good under some concept of "accuracy is good" but in practice it means it's not particularly flexible. I'm not familiar really with C3D but I worry there about support and communication with the development happening very far away from me in a different country. KCM seems to have the most modern code base and has the most potential for continued progress.
I still have yet to see how things will work out, but a while ago I already spent a chunk of time evaluating Parasolid and found it too finicky on what imported geometry it would accept particularly with closed surfaces. It might be a somewhat different matter if everything was constructed in it from the very beginning but I'd like to have a very high amount of compatibility with existing geometry and not have older models rejected by the kernel because a closed surface has a 0.1 degree deviation at its seam for example.
So yes indeed there is a lot to consider and I have been doing just that.
Also ACIS and Parasolid are run by these sort of giant corporate machines which are very annoying to deal with. They only seem to care about dealing with other big corporate entities. With KCM on the other hand I've been able to meet directly with the head of development and they are much more pleasant to work with. It seems to be a much better fit for me. I won't know more until I get to that stage of my v4 development cycle, I'm not quite there yet.
Show messages:  1-13  14-33  34-53  54-73  74-93  94-98
