Hi Bill,
> I thought the discussion was how to make the center point stay visible forever.
Yes, but I was just wondering _why_ you wanted the center point to stay visible - I mean what were you trying to accomplish by having that. I just wanted to mention that if it was for moving the object to somewhere else, you can use the Transform > Move command for that without needing to create an extra point.
If it's for some other purpose, then yes the BoundingBoxCenter command will do that for you - is it all cleared up now how you run it now? You can also set it up on a shortcut key, under Options > Shortcut Keys.
