2 MoI Problems
All  1-10  11-13
7948.11 In reply to 7948.9
Sorry Michael,
" I was trying to follow along with the dialog in the discussion. My question went like this:
"Sorry for butting in on the discussion. If I draw a circle, then select it and hit tab the only place it allows me type is in the box where you type in the x, y, z coordinates for a point. Is that where I am supposed to type "BoundingBoxCenter". If I do nothing happens. "
I see what you are saying regarding the move command, but when you use that command the center point only stays visible while you are in the command. I thought the discussion was how to make the center point stay visible forever.
I could not see how by hitting a tab key, I would be able to enter the command "BoundingBoxCenter", unless they have a shortcut that leads them to a move command somehow.
Sincerely,
Bill
7948.12 In reply to 7948.11
Hi Bill,
Yes, but I was just wondering _why_ you wanted the center point to stay visible - I mean what were you trying to accomplish by having that. I just wanted to mention that if it was for moving the object to somewhere else, you can use the Transform > Move command for that without needing to create an extra point.
If it's for some other purpose, then yes the BoundingBoxCenter command will do that for you - is it all cleared up now how you run it now? You can also set it up on a shortcut key, under Options > Shortcut Keys.
7948.13 In reply to 7948.12
Michael,
Thank you again for all you advice.
Sincerely,
Bill
Show messages: All  1-10  11-13
