Adding notes to objects
7943.1
Would be nice to be able to add a note to anything you create, especially fillets and chamfers.. I frequently forget what measurements I used for say, a fillet on a cube and then when I go to use the same size fillet somewhere else, I can't remember what I used earlier.. if there was some kind of annotation or note I could "attach" to any given item, that would help a lot.
7943.2 In reply to 7943.1
You can use the dimension system by Max Smirnov!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7403.103
7943.3
+1 upvote for that idea. I regularly find myself wanting to stick notes here and there to certain objects, fillets, curves, and so on. Would be nice to have a note system similar to that of Photoshop.
7943.4
+1
i did suggest this ages ago, would be really helpful for general documentation and design reviews. It might be even doable via some fiendish script. Maaaaaaaaaaaaaaaaaxx......
7943.5 In reply to 7943.1
Hi Moriturimax,
Just pick the edge of the fillet and MoI will tell you what it is.
