kit-bashed car
All  1  2-5
7941.2 In reply to 7941.1
Great looking vehicle :) You may need to drop the angle under your options screen to speed the screen back up
Martin
7941.3
Thank you Martin!
I'm not sure I got it right. Which angle should I drop?
I hope it's not the mesh angle in the meshing parameters section, because I tried and set it to 5 instead of the default 10 and the program halted and quit. LOL
(And BTW what are the meshing parameters?)
7941.4 In reply to 7941.1
Hi giai77, it's looking great!
If the display is bogging down for you, you can try adjusting some settings to help with that. Before you open your file, go to Options > View > "Meshing parameters" and set "Mesh angle" to 25 degrees and uncheck "Add detail to inflections".
That will make for a somewhat rougher looking shade display but also greatly reduce the triangle count.
7941.5
OK, got it! Thank you Michael!
Show messages: All  1  2-5
