Import .Ai from MOI to Inkscape last version? 2D export.
All  1  2-9
7918.2 In reply to 7918.1
Hi Pierre - MoI exports AI files using the AI v8 format. The AI file format changed a lot around AI v10 or so, I think Inkscape only supports reading the newer kind which are actually PDF files.
For going into Inkscape, I would recommend using PDF format, since Inkscape does not support reading in the type of AI file that MoI exports.
7918.3 In reply to 7918.2
thank you
7918.4 In reply to 7918.3
hi grandpi
i owned Inkscape 0.48 and MOI 3.0 ( with WINDOWS XP )
it works for me.
I export from M.O.I in .ai file
I import in Inskape using Adobe Illustrator 8.0 and .... ( take a look on the following pictures )
Chri
7918.5
Hello Christian,
Thank you for your reply.
Inkscape 0.91 (last version) cannot import MOI 3.0 .Ai export. : Back to the past (or use .PDF)!
Regards,
Pierre
works fine under OS X.
https://www.behance.net/futagoza
EDITED: 30 Oct 2016 by STEFAN
7918.7 In reply to 7918.6
Don't work with windows for me ? Strange ...
Pierre
7918.8 In reply to 7918.7
Don't work for me too (Windows 10)
7918.9
If it can be of any help, when exporting from MoI Mac version, I first open the file in Illustrator for Windows and save it (Converted). Then I'm able to open it with Inkscape .91 Windows version.
Michel
Show messages: All  1  2-9
