how to fillet this one?
All  1-3  4-8
7911.4
Thanks Mauro,
I know this technique, but I had other non planar curves in the design that I could simply fillet with the fillet tool, without problems, so I was wondering why this one did not work properly.
wim
7911.5
apparently, if non planar straight lines are filleted, it works, but if there is a smooth curve involved, the fillet tool does not work. 2 straight lines in a crooked angle are still planar, I realize now, even if they are not parallel with x, y or z.
7911.6
extrude -> fillet -> select edge -> copy -> paste
EDITED: 7 Mar 2022 by SMIRNOV
7911.7
that's a nice one (and fast too!), Max! thanks.
wim
7911.8 In reply to 7911.5
Hi Wim, yes for curve filleting the curves need to be coplanar. And like you figured out, they can be on any oriented plane not just ones aligned to an XYZ axis.
Show messages: All  1-3  4-8
