Hide command bar
All  1-2  3-6
7907.3 In reply to 7907.1
Hi Tom, do you mean the bottom command bar that contains the File menu, Save, Undo, Redo buttons in it? Or do you mean the view controls toolbar at the bottom of the viewports that has the Area, Zoom, Pan, and Reset buttons in it?
For the view controls toolbar, there's a checkbox for turning those on or off under Options > View > "Show view controls" checkbox.
For the bottom command bar with the File menu, use the following script on a shortcut key:
script: /* Toggle command bar on/off */ var cb = moi.ui.getUIPanel( 'moi://ui/CommandBar.htm' ); var body = cb.document.body; body.style.display = (body.style.display == '' ? 'none' : '');
7907.4
Thank you both !
I mean the bottom command bar that contains the File menu, Save, Undo, Redo buttons .
Filou > the fullscreen script unfortunately makes also the browser and menus disappear on the second monitor, what I dream of is
fullscreen on the left monitor while keeping the browser and menus on the right one for editing
Michael > The scripts erases the text and symbols from the bar, but it does not give more viewport space / real full screen as the
bar keeps in place - only without visible commands.
If it not possible to make the commandbar disapear while keeping browser and menus open - maybe it is possible to narrow the
commandbar by hiding only the text descritions line "file, save, ect) ?
EDITED: 31 Mar 2016 by SIRTOM
7907.5 In reply to 7907.4
Hi Tom,
> viewport space / real full screen as the bar keeps in place - only without visible commands.
Are you using MoI version 2 or version 3? I assumed you were using version 3 and over here at least the script I posted makes the entire command bar hide as you want. For v2 it won't work quite right, the v2 UI is structured slightly differently and needs a slightly different script, here is one that should work for either v2 or v3:
script: /* Toggle command bar on/off v2 compatible */ var cb = moi.ui.getUIPanel( 'moi://ui/CommandBar.htm' ); var body = cb.document.body; body.style.display = (body.style.display == '' ? 'none' : ''); try { moi.ui.getUIPanel( 'moi://ui/CommandBarRight.htm' ).document.body.style.display = cb.document.body.style.display; } catch(e) {} moi.ui.mainWindow.contentChanged();
It is possible to hide the text descriptions for File/Save/Undo/Redo/Delete, but I don't think it will save any space (maybe just a couple of pixels) since the view tabs and XYZ / Distance / Angle input controls will still be about the same height anyway.
7907.6
Fantastic ! - one more little step towards the perfect workflow.
Still a novice as I only recently started working seriously with MOI (although owning it for a while now) I will switch
to V3 when I unvelied all the secrets of the already so powerful V2.
Show messages: All  1-2  3-6
