Spiral script 2D for setting out Corinthian capital scrolls
 1-11  12-31  32-36
Here is an alpha version for IonicVolute.
It works, but still needs some improvement or corrections.
I'm guessing atan may be a problem.
10 minutes to code, 10 minutes to debug, 30 minutes to fiddle.
Edit: See post 7903.16 for updated, corrected IonicVoluteAlpha02.
EDITED: 31 Mar 2016 by BEMFARMER
7903.13 In reply to 7903.11
Ok No problem Brian
Polyskelion looks good although the transition from one spiral to the next is not as smooth as I would want so may do manually for a clean S form, each of the individual spirals created are pretty good though
Your help with this is very much appreciated
Andy
7903.14 In reply to 7903.12
Ok wow that was quick Brian
Can I make a donation for your time and effort ?
Possible improvements to the control the output
A) The spiral lines increase in distance apart smoothly, which is spot on :-) but can we control this increasing % in any uniform way ?
B) Also would it be possible to control the inner starting radius or diameter ?
The a & b values control in the script ? the size of spiral produced using the script seems to be about 25mm / 30mm - can this be increased if the maths allows or do I just need to scale up ?
atan - ? not sure what this refers to ?
This in effect will become the artist perfect set of french curves in MOI if you can devise a way to control A & B above
best wishes
Andy
7903.15 In reply to 7903.14
Hi Andy,
No donations please, this is for hobby/ fun/ occasional utility ☺
The script can likely be improved. I do not feel that I have a good understanding of the math yet, including "a" radius, "b" radius, and eye radius.
-B
The IonicVoluteAlpha01 had a glaring error in the formula, bvalue instead of the correct beta.
The default parameters now re-create the volute with the "historic" proportions. The two end tangents are not horizontal.
Added a parameter for the eyeRadius, the inner end of the spiral. Renamed bvalue to bRadius.
In the event that the eyeRadius exceeds the bRadius, the bRadius is "inner" rather than "outer."
Negative values for Whorls or eyeRadius are strange. May add absolute value to them.
Next to do are sliders, counter clockwise, and start angle.
- B
7903.17 In reply to 7903.16
Brian
Hey great, its working just fine thank you :-)
Look forward to the final version
Andy
7903.18 In reply to 7903.17
Here is the "final" version of the IonicVolute script.
After creating one spiral, making a second spiral, with the only change being the "offset" parameter, leads to an interesting surface or extrusion, which can be filleted.
The notes were modified, and are in the .js file. The tangent equation was substituted into the logspiral4 script, with additional modifications.
EDITED: 4 Apr 2016 by BEMFARMER
7903.19 In reply to 7903.18
The "inside" of the spiral:
7903.20 In reply to 7903.18
Great thank you Brian
The sliders are a big help to get things looking visually right for my projects
and your offset spirals look good, looking forward to playing with the script properly
I have updated my LogSpiral script to version 4
Again many thanks for all your work on this
Best wishes
Andy
7903.21 In reply to 7903.20
Thank you Andy.
- B
7903.23
Awesome script
Thank you
James Elliott
www.jameselliott.co.uk
This trial version adds a Z axis offset, for a 3D spiral, in 3D view.
-B
7903.25 In reply to 7903.24
Thanks Brian!
Off topic, sorry.
EDITED: 11 Apr 2016 by SBEECH
Ionic volute of Giuseppe Porta Salviati (1520-1575).
There is an excellent video here:
https://www.youtube.com/watch?v=HBh04ZtnLDM
The 3 "quarter circle" arcs in the upper left are actually slightly more than quarter circles.
Intersection with the eye is not quite tangent.
EDITED: 11 Apr 2016 by BEMFARMER
7903.27
Hi Brian
Will it be possible to make the script use an other folder than the original "command" folder?
I am currently using a subfolder to the command folder containing the scripts i use often, here i also put new scripts for test so they are easy to find :-)
7903.28 In reply to 7903.27
Hi hep - there are 2 different ways that scripts can be run, either as a "command" which has UI associated with it (like in this case), or as "immediate script".
For the command type those have to be located in MoI's command folder in order for MoI to run them.
7903.29
Hi Michael
Thanks - i see.
that was a quick answer - I just love this program and it's forum :-)
7903.30 In reply to 7903.28
...what about the "scripts" folder instead ?
I see that also this folder is a suitable place for scripts, that haven't a UI associated, in order to be executed.
Thanks and nice day,
Marco.
EDITED: 11 Apr 2016 by MKDM
Some of the old Ionic Volute methods produced gaps between some of the quarter circles, which is often not mentioned.
In the 2005 book, The Classical Orders of Architecture, by Robert Chitham, the simple method of Chambers is given.
The Chambers method uses quarter circle arcs, without gaps. The results seem superior.
Surprisingly, it seems that a legitimate pdf of the book is available:
https://archive.org/details/The_Classical_Orders_of_Architecture_2nd_ed_R._Chitham_Arch._Press_2005_BBS
https://archive.org/download/The_Classical_Orders_of_Architecture_2nd_ed_R._Chitham_Arch._Press_2005_BBS/The_Classical_Orders_of_Architecture_2nd_ed_R._Chitham_Arch._Press_2005_BBS.pdf (free)
For the offset curve, called a "fillet," I used a sweep with pointy end, rather than finish laying out a second set of cyan points in the eye and drawing more arcs,
which are slightly different than the sweep.
- B
EDITED: 13 Mar 2019 by BEMFARMER
Show messages:  1-11  12-31  32-36
