Changing rotational axis of 3D view ?
7900.1
I am really thankful for your MirrorRotateHistory Array Script - amazing time saver !!
Here my question : The script works within the xy-plane (top view). Thats perfect while working in 2D (top-view)
but when switching to / working within the 3D view it gets difficult to handle as the 3D view rotates around the z-axis.
Is it possible to change the rotational axis of teh 3D view to the y axis ? (or generate the symmetrical array in another plane ?)
Another question : Is it possible to lock the rotational axis in the 3D view so that rotaion will take place only around one single
axis ?
PS : I use mouse / tablet pen for viewport navigation
EDITED: 28 Mar 2016 by SIRTOM
7900.2 In reply to 7900.1
Hi Tom,
Sorry no there isn't any way set up to make the 3D view rotate only around the yaxis. But it is possible to modify the script to change which plane it makes stuff on.
To change it, open the script in a text editor and you'll need to edit 3 lines, the first one is line number 12 which has this:
mirror_factory.setInput( 1, moi.vectorMath.createTopFrame() ); // First point and plane for mirror line.
Edit that to use createFrontFrame() instead. Then line number 13 has this:
mirror_factory.setInput( 2, moi.vectorMath.createPoint(0,1,0) ); // Second point of mirror line.
Change that to say moi.vectorMath.createPoint(0,0,1) so the mirror line will be going up in the world z direction. Then the last place to edit is line number 34 which has this:
Set that to say createFrontFrame() as well. After those modifications, the script should generate the pattern in the Front view instead of the Top view.
Sorry no there isn't any way to do that for mouse rotation. But it is possible to set up the arrow keys so they will do rotations, see here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6145.2
7900.3 In reply to 7900.2
Very cool, Michael and thank you.
Sorry for repeating myself but your software is really a pleasure to work with -
and the more I dig into MOi to more I admire the simplistic and yet very ingenious
approach behind it.
7900.4 In reply to 7900.3
Thanks Tom, I'm glad that you are liking MoI!
7900.5 In reply to 7900.4
"Sorry no there isn't any way to do that for mouse rotation. But it is possible to set up the arrow keys so they will do rotations, see here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6145.2"
This kind of locked rotation is very useful to judge the design of an object from all sides
while refining its shape incrementally. Make a little change- rotate and judge, another
change.-rotate, etc. Like a model on the end of a catwalk ;-)
But : The rotation is is not smooth as it works with steps of 3° and it rotates pretty fast.
Is there any way of making the rotation smooth and slow ? Thx TOM
7900.6 In reply to 7900.5
Hi Tom,
For the arrow key movement as described here:
You can change that to be slower by editing the script, where it has the value of 3.0 in the script change it to a smaller value like 1.0 or 0.5 or whatever works best for you and that will make the arrow keys rotate in smaller increments.
7900.7 In reply to 7900.6
0,25 is an awesome speed ;-) one more step towards the ultimate
MOI workflow - grazie !
