http://kyticka.webzdarma.cz/3d/moi/#SetView
All  1-2  3-6
7898.3 In reply to 7898.2
Thank you, Michael!
Method "upDown Angles to be first" works great!
All views are switched from the first time!
7898.4
Hi Michael
Can this be added to the scripts above to reset the view first
script:moi.view.resetAll();
thanks
shayne
7898.5 In reply to 7898.4
Hi shayne,
Yes, you can add that if you want. Just insert moi.view.resetAll(); into any of the previous scripts, like so:
script: moi.view.resetAll(); var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.upDownAngle = 0; v.leftRightAngle = 0; v.tiltAngle = 0;
7898.6 In reply to 7898.5
Unfortunately when viewed from above "Alt + W" not visible EditFrame. ( v.upDownAngle = 0 )
But when set the minimum angle of 0.1 it works ( v.upDownAngle = 0.1 )
Alt + W = script: var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.upDownAngle = 0.1; v.leftRightAngle = 0; v.tiltAngle = 0;
Show messages: All  1-2  3-6
