http://kyticka.webzdarma.cz/3d/moi/#SetView
All  1  2-6
7898.2 In reply to 7898.1
Hi GonzoRus, I think it has to do with the order that these rotation values are processed internally - in the function that processes the view angles it rotates by the up/down angle first and so I think the script also needs to do that one first as well.
Try these instead, here I've just moved the upDownAngles to be first:
Alt+W=script:var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.upDownAngle = 0; v.leftRightAngle = 0; v.tiltAngle = 0;
Alt+D=script:var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.upDownAngle = 85; v.leftRightAngle = 90; v.tiltAngle = 0;
Alt+Q=script:var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.upDownAngle = 45; v.leftRightAngle = 45; v.tiltAngle = 0;
Alt+E=script:var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.upDownAngle = 85; v.leftRightAngle = 0; v.tiltAngle = 0;
Or also there's a method that takes all 3 numbers in one call, v.setAngles( updown, leftright, tilt ) , I think that would also solve the problem and would look like this:
Alt+W=script:moi.ui.mainWindow.viewpanel.getViewport('3D').setAngles( 0, 0, 0 );
Alt+D=script:moi.ui.mainWindow.viewpanel.getViewport('3D').setAngles( 85, 90, 0 );
Alt+Q=script:moi.ui.mainWindow.viewpanel.getViewport('3D').setAngles( 45, 45, 0 );
Alt+E=script:moi.ui.mainWindow.viewpanel.getViewport('3D').setAngles( 85, 0, 0 );
Do these versions behave better for you?
7898.3 In reply to 7898.2
Thank you, Michael!
Method "upDown Angles to be first" works great!
All views are switched from the first time!
7898.4
Hi Michael
Can this be added to the scripts above to reset the view first
script:moi.view.resetAll();
thanks
shayne
7898.5 In reply to 7898.4
Hi shayne,
Yes, you can add that if you want. Just insert moi.view.resetAll(); into any of the previous scripts, like so:
script: moi.view.resetAll(); var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.upDownAngle = 0; v.leftRightAngle = 0; v.tiltAngle = 0;
7898.6 In reply to 7898.5
Unfortunately when viewed from above "Alt + W" not visible EditFrame. ( v.upDownAngle = 0 )
But when set the minimum angle of 0.1 it works ( v.upDownAngle = 0.1 )
Alt + W = script: var v = moi.ui.mainWindow.viewpanel.getViewport('3D'); v.upDownAngle = 0.1; v.leftRightAngle = 0; v.tiltAngle = 0;
Show messages: All  1  2-6
