Combine curves
7897.1
Hey there
Rookie question here I presume:
Im trying to combine to curves (that touch each other). Join works, but I would like it to merge them permanently, without the the line the shows when you make a surface out of it. I tried the merge command, but nothing happens.
Any ideas?
/Nick
7897.2 In reply to 7897.1
Hi Nick, currently the Merge command only merges split up edges into longer edges - in the future I want to have some way to do that to regular curves yet but I've been thinking about possibly modifying the Join command to have that functionality.
Currently the main way to merge smooth meeting curve segments into longer segments is to use the Rebuild command:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#rebuild
7897.3 In reply to 7897.2
Allrighty, rebuild it is. Thanks Michael!
