Island Selection from poly
All  1  2-4
7890.2 In reply to 7890.1
Hi ndrakey, also see my reply to your other post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6988.9
> Is there a way to select all faces on objects by selecting only one face
> and expand that selection?
Use "Select All" / Ctrl+A for that, once you have selected one face if you then use Select All (Ctrl+A), the selection will expand to all the faces on objects where you have at least one face selected to start with.
> Also it would be nice to select one point/ edge and expand it to
> full selection of all points/edges on an object too.
Same thing for these - Select All / Ctrl+A will also select all edges of an object if you have at least one edge selected initially, and also if you have at least one control point selected using Ctrl+A will select all points of that object.
7890.3 In reply to 7890.2
Wow! Didnt know that function was already there! Thanks Michael!
One more question:
Is there a way to convert face selection to selection of boundary edges or points of that face and vice versa?
7890.4 In reply to 7890.3
Hi ndrakey,
There isn't any way to do the points one, but for edges a script like this might be what you're looking for:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5922.37
or maybe this:
http://kyticka.webzdarma.cz/3d/moi/#SwitchSelectionFromFaceToEdges
Set up those scripts on a shortcut key (Options > Shortcut keys) to use them.
Show messages: All  1  2-4
