Hi ndrakey, also see my reply to your other post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6988.9
> Is there a way to select all faces on objects by selecting only one face
> and expand that selection?
Use "Select All" / Ctrl+A for that, once you have selected one face if you then use Select All (Ctrl+A), the selection will expand to all the faces on objects where you have at least one face selected to start with.
> Also it would be nice to select one point/ edge and expand it to
> full selection of all points/edges on an object too.
Same thing for these - Select All / Ctrl+A will also select all edges of an object if you have at least one edge selected initially, and also if you have at least one control point selected using Ctrl+A will select all points of that object.
