Modeling help
All  1-3  4-6
7887.4
Thank you both for the suggestions. Wish I had seen this post earlier - I'm not getting email notifications for some reason. I will install the trial version tomorrow and see what I can do over the next few days. Quick question - is there any limitation to the number of paths or sources I can use with the sweep? I am looking forward to diving into Moi3D. Thanks again! Kevin
7887.5 In reply to 7887.4
Hi kmccall, the e-mail part of this forum is a little flaky, you might not always receive e-mail notifications from it.
Sweep can use any number of cross-section profile curves, and either one or two rail curves as paths. You can also select more path curves than that, but when you do that it's used as a batch mode for doing a one-rail sweep along each of those separately like making a bunch of tubes in one pass.
But the sweep mechanism works by either one or two path curves for shaping the surface. If you want to use more curves than that in the path direction, then there is a different surface construction tool called Network which works somewhat differently from Sweep and Network can take any number of curves in each direction.
7887.6 In reply to 7887.5
Michael, thanks again! It looks like it won't be until the weekend that I can dive in. Kevin
Show messages: All  1-3  4-6
