Surface selecting
All  1  2-4
7882.2 In reply to 7882.1
Hi Mike, if you go and select one face of an object you can then use Ctrl+A / Select All to select all faces of that object.
That will select all the faces of that object though, not just ones directly connected to it. The only time you should end up with one object that has different groups of surfaces in it is a hollow object that has an inner void area in it that is not connected to the outer surface. Is that the kind of thing you're working with?
7882.3 In reply to 7882.1
Hi Mike, also see here for a script that will grow the selection from one selected face to its neighboring attached ones:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6988.4
Set that on a keyboard shortcut and then keep triggering it until the selection has spread all the way through.
You can use that if you want to extract out the outer or inner piece of a hollow solid with a cavity in it.
7882.4
Good morning Michael,
My model, although it could be/should be two parts, appears to be fushed or one. When I select one surface and hit command A It selects the entire model. I will need to dissect the surfaces, separate them manually. I'll try the scripts you mentioned.
Mike
Show messages: All  1  2-4
