Wrong G2Blend result on Twisted Surfaces
All  1-6  7-11
7869.7 In reply to 7869.6
"...It's possible that just the scaling down alone would do it, maybe the trimming was not needed after all."
You're right ! (obviously.....)
I tried your suggestion and it works :
1) scale all to 0.1
2) create the G2 blend
3) join all and...
voila ! The piece is a solid!
The last part of your answer remain obscure for me...
"Another thing I've thought about trying is to extend the blend surfaces sideways and then I might be able to intersect them better with each other."
I tried to do a "scale 1D" on each single blended surface, but i think i misunderstood your thought.
But now it's not so important.
Thank you very much !
Marco.
7869.8 In reply to 7869.7
Hi Marco,
> your thought.
Yeah I'm talking about a different kind of extension, one that keeps the current surface shape as it is and iit just grows outwarrd from there. That kind of extension can go a little crazy if the surface is very bendy though.
- MIchael
7869.9 In reply to 7869.8
Hi Marco,
no, you understood right...but the planar command worked for me, as you can see.
https://www.behance.net/futagoza
7869.10
An alternative idea:
Do the Blend between two edges
select yellow edges,copy them and paste using same snap point (end-middle)
Extract isocurve from blended surface,snapping in the middle
delete blended surface,select three curves and two edges and do Network
repeat same operation with second set of edges :Blend surface-extract middle isocurve ,copy last yellow curve from Blend and copy first curve from Network.
Now do the second Network surface
Now join one by one all four surfaces ,then join with the rest and you'll obtain a solid
If you want to simulate better the Blend behavior you need to extract more curves:turn on points of blended surface
Extract isocurves snapping on the points
M
7869.11 In reply to 7869.10
Hi Mauro,
Thank you very much for your effort and your suggestions.
It's a very smart method to operate, although it seems a bit complex.
But, evidently, to achieve a good result there's need to work hard :)
I will try it as soon as possible.
Thanks again,
Marco.
Show messages: All  1-6  7-11
