the best practice to draw this jar
All  1-4  5-14
Miam miam!
7863.6
Thanks a lot Mauro.
Can I use the same practice with a conical model like the Bonne Maman jar ?
7863.7
for the conical form, i've opened my 3dm file in Rhino and use a transform tool (taper), save it and reopen it in MoI.
thanks for your help
EDITED: 9 May 2020 by FINEMA
7863.8
I'm happy to talk about modeling techniques and spend my spare time for it :)
This is MOI:a modeler first of all,not a script or math formulas container ;)
Jar tapered 6°
Rail revolve:yellow curves, profile and 8-sides as rail
Draw a polyline (yellow) always extended to avoid problems when boolean difference
Fillet the polyline to 30 mm
Extrude in both ways,once again extended as said above
Rail revolve:this will be the Jar
Turn on previous surface
Polar array:8 copies
Bool difference:subtract 8 copies and deleting
Select solid and hit fillet=5mm
Pushing fillet to 40mm
model attached,open the browser to get construction lines
M
7863.9
really cool!!
thanks again
7863.10 In reply to 7863.9
You can make it in less steps.
Extrude between upper and lower circles and proceed as above.
7863.11
Sure you can do it in less steps,i just expanded for better understanding
Now it depends what shape you want and if you can fillet the solid
There are little differences between two workflows
Can you fillet it ?
If you want different fillet radius between blue edges and the rest you can fillet first using red line lenght as radius,not more
I follow your workflow without fillet the surface to subtract
when i do the final fillet it doesn't work (radius 1mm)
Fillet engine must have good conditions to work(as Michael explained many times),little variations can make the difference
Probably this is happened to Finema
M
7863.12
Hi
I meant loft not extrude but that may not make any difference. I did fillet it at the end and it worked ok. I'm not being competitive just pleased to have made it so simply. Of course I might have been lucky as I often find when I try and make an exact model filleting can be tricky.
Keith
7863.13 In reply to 7863.12
Thank you Keith for your suggestions :)
I used Rail Revolve instead of Loft to get an exact revolved surface
No competition-just share !
M
7863.14
it's a good thread, thanks
Show messages: All  1-4  5-14
