the best practice to draw this jar
All  1-9  10-14
7863.10 In reply to 7863.9
You can make it in less steps.
Extrude between upper and lower circles and proceed as above.
7863.11
Sure you can do it in less steps,i just expanded for better understanding
Now it depends what shape you want and if you can fillet the solid
There are little differences between two workflows
Can you fillet it ?
If you want different fillet radius between blue edges and the rest you can fillet first using red line lenght as radius,not more
I follow your workflow without fillet the surface to subtract
when i do the final fillet it doesn't work (radius 1mm)
Fillet engine must have good conditions to work(as Michael explained many times),little variations can make the difference
Probably this is happened to Finema
M
7863.12
Hi
I meant loft not extrude but that may not make any difference. I did fillet it at the end and it worked ok. I'm not being competitive just pleased to have made it so simply. Of course I might have been lucky as I often find when I try and make an exact model filleting can be tricky.
Keith
7863.13 In reply to 7863.12
Thank you Keith for your suggestions :)
I used Rail Revolve instead of Loft to get an exact revolved surface
No competition-just share !
M
7863.14
it's a good thread, thanks
Show messages: All  1-9  10-14
