> 1. Which tolerance are you using? Its the tolerance customizable?
The tolerance used is 0.001 units, it is not customizable.
> 2. Its possible to make solids?
Yes, surfaces can be joined along common edges and if all edges of an object are joined to another edge, you will have a "water tight" solid object. You can also use Edit/Separate to break a solid into individual surfaces, edit the surfaces, and then later on use Edit/Join to bring it back into a fully closed solid object again.
So in this sense MoI is what is called a "hybrid" modeler, it works with both surfaces and solids.
> 3. About the curves. Which degrees for the curves its possible to use?
> Is also possible to switch from a 4 degree curve to a 7 or 9 degree curve just typing the degree?
Curves and surfaces up to around degree 31 can be used by MoI. But MoI does not currently have any UI to change the degree of a curve. That's something that will likely be added in a future version.
> 4. About the Surfaces. Its possible to manipulate the surfaces to correct the desired shape?
Yes, it is possible to select a surface and use Edit / Show pts to turn on control points for the surface, then control points can be manipulated. But this type of manipulation is not really a big focus in the current version of MoI.
> 5. Its possible to make free form surfaces, i guess its possible, well if i
> want to make a surfaces and connect to another which tangential will be obtain?
You can use Construct / Blend to create a surface that will be tangent or curvature continuous between existing edges. But currenty MoI does not have a lot of controls for continuity in other situations, that's another area that will likely be enhanced in future versions.
> 6. Do you have a zebra shading to analyse the continuty of the surfaces?
Nope, not in MoI version 1.0.
MoI 1.0 is focused more on very fast and fluid creation of more simple objects.
