To revolve a curve, MOI asks for the axis and an angle.
During a larger project I always use revolve around the origin, the z-axis and 60 degrees.
Is it possible to create a customized command for this action - does a script exist ?
Hi Tom, yes it's possible to create a customized version of the Revolve command that works like you are asking about.
The regular revolve command is controlled by the file Revolve.js in the commands folder. If you make a copy of that file and edit it to just make it set your desired values rather than the way it regularly works by getting the values from UI controls then that would do what you want.
This version expects for you to preselect the curve before you run the command, and so the command has no UI of its own and so only has a .js file and no .htm file in it.
