moi 3dm / SimLab
 1-20  21-24
7835.21 In reply to 7835.20
I think that the simulation is a blend of physics and paths.
For example the part that is moved 'horizontally' is moved by physics but it has a constraint put on it so that it can only move in a straight line.
The constraint is necessary because I haven't included the base as an active part of the simulation.
The part that is moved vertically and one can see wobbling is physics only. It is restrained by interaction with the part within which it slides. And I have to give quite a bit of clearance at the design stage to cope with the inaccuracies of the 3D printing process that I'm using.
The gears and other rotating parts are constrained to rotate around a fixed axis.
As for the pdf.
I'm using Windows 10 64 bit.
The pdf does do something odd with the colours so that they are sometime quite different from the videos but for me they are always coloured and do not need to clicked on.
I planned to attach a pdf of the final design to see if that worked better for you but it's 24Mb so I've attached a pdf of an earlier project which is rendered in wood!
7835.22 In reply to 7835.21
Thanks for the infos!
This last Wood PDF 3D works like a charm with all pieces in different color materials and of course the animation too!
I am right if I say that in this PDF 3D I can't rotate the handle for move the system of gears ?
7835.23 In reply to 7835.22
I wonder why that 3D pdf worked for you and the other did not. A mystery.
You are right, the animation is not interactive.
However one can rotate the model, which stops the animation, and then re-start the animation looking from a different ange.
I expect that you are already doing this - just making sure.
7835.24 In reply to 7835.23
<< I wonder why that 3D pdf worked for you and the other did not. A mystery.
yes colors of gears are dispeared on the first PDF as like the light keep them in shadows and kill colors! :)
Ask if its the same for other users!
<< You are right, the animation is not interactive.
just making sure ;)
<< However one can rotate the model, which stops the animation, and then re-start the animation looking from a different ange.
Of course! ;)
Show messages:  1-20  21-24
