offset
All  1-2  3-7
7832.3 In reply to 7832.2
Thanks Michael,
I am amazed that you answer so quickly and clearly.
So, is the basic problem in the 'flow' construction?
Are suggesting that perhaps I could make a copy, scale it appropriately, insert it into the original solid and then boolean it out?
I'll just try that myself.
cheers,
eric
7832.4 In reply to 7832.3
Yes,
That worked like a charm.
Thanks again Michael,
eric
7832.5 In reply to 7832.3
Hi eric,
Yup, something like that - it sounds like you've got it done.
7832.6
Hi Eric
I think one of your problems was the amount of points on the hex curve , if you rebuild the points it lofts better to the circle which usually has 12
It will then shell inside
cheers
shayne
7832.7 In reply to 7832.6
Thanks Shayno
I'll try that, too.
cheers,
eric
Show messages: All  1-2  3-7
