how to fillet this one?
All  1-5  6-7
7825.6
Thanks Michael, that seems to do the trick. I have the habit with filleting to take all the edges together since mostly it yields different results when doing it one by one, that is when the fillets are overlapping or touching.
thanks again!
wim
7825.7 In reply to 7825.6
No problem wim, I'm glad that worked for you.
Yes, normally when fillets run into each other it's better to do them all at once, especially so that the fillet engine can see that 2 fillets are running into each other and then construct a proper corner patch where they hit.
But in your particular case here since the fillets shrink down to a single point where they meet, there isn't any need for a corner patch to be created.
Show messages: All  1-5  6-7
