Scriptproblem with BReps and getNackedEdges
7819.1
Hello,
I try to join some adjacent faces and get the boundary edges/loop from the result. Unfortunately I can't find a solution to get the edges. Here is what I try to do:
function getloops()
var inputobjects = moi.geometryDatabase.createObjectList();
inputobjects = moi.geometryDatabase.getSelectedObjects();
var loops = moi.geometryDatabase.createObjectList();
var output = moi.geometryDatabase.createObjectList();
var joinedInput = moi.geometryDatabase.createObjectList();
var joinedFacesEdges = moi.geometryDatabase.createObjectList();
var joinedFacesLoops = moi.geometryDatabase.createObjectList();
var joinedBRep = moi.geometryDatabase.createObjectList();
// this.inputobjects = selectBylist(this.properties.selObjects);
// loops = this.inputobjects.getCurves();
// var facebundles = this.inputobjects.getFaces();
var facebundles = inputobjects.getSingleFaceBReps();
if (loops.length < 2)
var joinFac = moi.command.createFactory('join');
joinFac.setInput(0, facebundles);
joinedInput = joinFac.calculate();
joinFac.commit();
// joinFac.cancel();
joinedBRep = joinedInput.getOpenBReps();
// joinedBRep = joinedInput.getTopLevelObjects();
// this.outputs[0].label = this.inputobjects.item(0).GeomObjectEnum;
for (var i = 0; i < joinedInput.length; i++)
joinedFacesEdges = joinedBRep.item(i).getNackedEdges(); // getOpenBReps getSubObjects().getBReps()..getNackedEdges()
// joinedFacesEdges = joinedInput.getTopLevelObjects().getNackedEdges(); // getOpenBReps getSubObjects().getBReps()..getNackedEdges()
// this.outputs[0].label = this.inputobjects.item(i).GeomObjectEnum;
joinFac.setInput(0, joinedFacesEdges);
joinedFacesLoops = joinFac.calculate();
joinFac.commit();
loops.addObject(joinedFacesLoops.item(i));
//////////////////////testloft
var truncatedFac = moi.command.createFactory('loft');
truncatedFac.setInput(0, loops);
truncatedFac.setInput(2, 'Straight');
truncatedFac.setInput(3, false);
truncatedFac.setInput(4, false);
output = truncatedFac.calculate();
truncatedFac.commit();
// this.setOutputData(0, joinedFacesEdges);
//////////////////// end testloft
getloops();
Thanks in advance!
Have a nice day
Karsten
7819.2 In reply to 7819.1
Hi Karsten - it's a spelling problem there, (or more likely an unintended translation?) the name of that method is .getNakedEdges() - you've got an extra c in the middle there that needs to be removed.
That method will get edges that belong to only one face and are not joined between 2 faces.
The other edge getting methods you can call on a brep or face are:
getEdges() // Gets all edges
getJoinedEdges() // Gets edges that are joined between 2 faces (or seams too I think), leaving out naked edges
getNakedEdges() // The one you're trying to use
getSeamEdges() // Gets the seam edges of a closed surface.
Also another way to go through edges is to do it by the trim boundaries on a face by calling face.getLoops() - that returns a set of boundaries with the first boundary being the outer boundary of the face and any next ones being holes. Each boundary is itself a list of edges that make up the boundary.
Hope this helps!
7819.3 In reply to 7819.2
Hello Michael,
thank You very much! I will test it:-)
Have a nice day
Karsten
7819.4 In reply to 7819.3
Thanks again, Michael,
now everything works fine:-)
