MSPhysics
All  1  2-5
For no headache to see the volumes falling in the infinite!
Make a volume(s) : group it (them) (alone or separated)
Faire un volume(s) : le(s) "grouper" séparément ou pas!
Copy an existing group don't work except if you group all the result of the copy + original!
Draw a Joint any where in the 3 D Space
All can be selected in any order
but always with Keys Shift &/or CTRL
Colors Bounding box is helping!
Here 2 groups separarated + only one Joint!
Motors on wheels!
On a Static Ground
Draw a Joint (motor) on the axe of the piece (wheel) who will run!
Group this joint (motor) with this piece (wheel)! (SU Group)
CONNECTE this Joint (motor) to the parent piece (car) with MAJ &/or CTRL !
(Connection MSPhysics)
Miracle we can Copy / rotate etc...the whell + motor around the car!
Each motor can have different acceleration etc...
Better to put all joints on the same layer for hide them
And use component for at the end when all works fine replace the box car by a Bugatti! :)
EDITED: 11 Jan 2016 by PILOU
Works perfectly! :)
Show messages: All  1  2-5
