Planar not working on closed curve
All
1-3
4-10
Mauro (M-DYNAMICS)
6 Jan 2016 (4 of 10)
7800.4
Hi Nic :
a quick method is to project your closed curve on a flat plane,select the projected one and hit - planar surface- command
M
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
wastzzz
6 Jan 2016 (5 of 10)
7800.5
Select curve, show points, go in the front view, align top.
That's the cleanest way to make it planar without rebuilding the structure.
M.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
6 Jan 2016 (6 of 10)
7800.6
In reply to
7800.5
The edit frame has a "flat" snap that works well for this.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
6 Jan 2016 (7 of 10)
7800.7
In reply to
7800.6
Yeah I like using the edit frame for this, here's an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3378.4
If you don't see flat snap engage it means it was already flat.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
6 Jan 2016 (8 of 10)
7800.8
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
7 Jan 2016 (9 of 10)
7800.9
In reply to
7800.8
Hey frenchy,
The cost of that looks to be around 2 bits!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
7 Jan 2016 (10 of 10)
7800.10
In reply to
7800.9
@Burr
A flat coin indeed! ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-3
4-10
