X,Y,Z coordinates of a Distorted Circle
All  1-2  3-5
7792.3 In reply to 7792.1
Hello Ed,
If I get you right you can do something like that:
- place a point on the curve from you would start with your coordinatefile.
- make a transform-> array -> curve with the point as object and your circle as path curve, choose the resolution you want:-)
- select all points and run the script from http://kyticka.webzdarma.cz/3d/moi/#SavePointFile (put the 2 files in command and make shortcut key under options)
- share your results with us and make us happy:-) and give us inspiration:-)
Good luck
Karsten
7792.4 In reply to 7792.2
Oh,
there was someone faster!
Thanks guys - sounds like an easy plan.
I'll share if my final experiment is a success. It will take a while :)
Ed
Show messages: All  1-2  3-5
