Vectary
 1-5  6-25  26-37
7786.6
No download because seems that this is another browser solution like Onshape.
7786.7 In reply to 7786.6
Hi
I had another look and it says GOING LIVE THIS SPRING! LINE UP TODAY FOR LIMITED EARLY ACCESS! just above the space to enter your email.
Keith
Sure and it's starting this Spring! ;)
7786.9
Would anyone please enlighten me?
How do cloud base online apps work actually?
I mean: how do they (the developer) make their earning?
They will have to spend time and energy to maintain the app, right?
Btw, it looks like a great program. Honestly, it's very similar to how i imagine the next MoI v4 will be
(in terms of simple UI and polygon modeling support... but hey, no push here... ;) ).
7786.10 In reply to 7786.9
That's an easy one ;)
In the beginning it's about different services and service levels. Single user with tiny online storage vs. Collaborative with unlimited storage and integrated PDM. Can you guess which one will be the paid one ? ;) But that's just an intermediate thing.
Ultimately, the business model is to get bought by a big player. When 3DS, Siemens, Autodesk or Google decide they need the technology. That's when money is made. VC firms bridge the cash needs and spin their rolodexes.
7786.11 In reply to 7786.9
It looks like Max compiling all his work into the customUI plug!!!!
7786.12 In reply to 7786.10
@Ditto:
Thank you very much for the explanation.
It's now make sense for me... :)
It's started and Online! (icons are small for my taste :)
https://beta.vectary.com/engine/
Free 5 private, rest public illimited - OBJ STL
EDITED: 20 Jun 2016 by PILOU
remember TopMod : http://www.viz.tamu.edu/faculty/ergun/research/topology/download.html
"Bridge" & "Bevel" & Radial menus excellent!
Show Red faces with problem !
Export easy! And import inside Sketchup with free Quad Faces tool by Thomthom
And no problem for input inside Moi with _importObj then Subdiv both by Max Smirnov!
7786.15
Hey Pilou, is it one of those web based application with stupid cloud service, or is it possible to run it locally (standalone) and offline ?
7786.16 In reply to 7786.15
<< Do I have to install anything?
No, all you need is a web browser with an internet connection and you are ready to roll. All your projects are saved online in a cloud so you can reach them from anywhere. Just go to www.vectary.com and sign in with your active account.
J'ai bien que non! Que sur le Web!
I affraid that is only on the Web!
but all applications become to works like this! :)
My.sketchup, Onshape (you can't say for this last one "a stupid cloud" ! :)
https://my.sketchup.com/
https://www.onshape.com/
etc...beginning of a new era! ;)
7786.17
This program surely is far more "ultimate" than the other "ultimate" 3d tools I worked with for the past 20 years. ;-)
7786.18 In reply to 7786.17
...but it's not so bad! ;)
https://beta.vectary.com/learn3d/video-tutorials/video-tutorial-propeller
And some funny to use! :)
EDITED: 23 Jun 2016 by PILOU
...no so bad! ;)
"Loop selection"
Make a bevel for make an Offset (Insert (?)) of face(s)
"Joints" on any volumes (here a sphere)
Icon's size follow display of Net Browser!
7786.22 In reply to 7786.21
It's fun to create a tube or a cube but for a professional work i think it's a dream
A lot of erzartz are on the web. OnShape and Cie.......
it is necessary to go down again on ground (je sais c'est une traduction directe FR / GB)
Si tu as essayé dix minutes de réaliser un projet pro avec ce genre de daube alors bravo
7786.23 In reply to 7786.22
Sure Fusion 360 or Onshape are some Pro! Seems sufficient and robust for not too large object!
All design for human size or little reasonable mechanical pieces!
About Vectary for Pro
Je ne pense pas que cela soit le but! :)
C'est juste pour les gens qui veulent s'amuser pour faire du 3D Print sans se prendre trop la tête! :)
It's not a Pro target, just fun for 3D Print without headache!
EDITED: 25 Jun 2016 by PILOU
Tested Free Vectary and free Rocket3F Import Export : No problem!
If you export for Moi3D just take objects with no millions of polys for the _importObj by Max Smirnov! ;)
then from Moi to Sketchup! ;)
EDITED: 20 Oct 2016 by PILOU
Show messages:  1-5  6-25  26-37
