Vectary
 1-17  18-37
7786.18 In reply to 7786.17
...but it's not so bad! ;)
https://beta.vectary.com/learn3d/video-tutorials/video-tutorial-propeller
And some funny to use! :)
EDITED: 23 Jun 2016 by PILOU
...no so bad! ;)
"Loop selection"
Make a bevel for make an Offset (Insert (?)) of face(s)
"Joints" on any volumes (here a sphere)
Icon's size follow display of Net Browser!
7786.22 In reply to 7786.21
It's fun to create a tube or a cube but for a professional work i think it's a dream
A lot of erzartz are on the web. OnShape and Cie.......
it is necessary to go down again on ground (je sais c'est une traduction directe FR / GB)
Si tu as essayé dix minutes de réaliser un projet pro avec ce genre de daube alors bravo
7786.23 In reply to 7786.22
Sure Fusion 360 or Onshape are some Pro! Seems sufficient and robust for not too large object!
All design for human size or little reasonable mechanical pieces!
About Vectary for Pro
Je ne pense pas que cela soit le but! :)
C'est juste pour les gens qui veulent s'amuser pour faire du 3D Print sans se prendre trop la tête! :)
It's not a Pro target, just fun for 3D Print without headache!
EDITED: 25 Jun 2016 by PILOU
Tested Free Vectary and free Rocket3F Import Export : No problem!
If you export for Moi3D just take objects with no millions of polys for the _importObj by Max Smirnov! ;)
then from Moi to Sketchup! ;)
EDITED: 20 Oct 2016 by PILOU
7786.26
Hmm… I can make such a poly model faster in blender. :)
I'm a bit fed up with poly modeling personally. I love not having to think about the structuring of polygons in MoI and ZBrush, and determine the polygon structure only after modeling. Such a workflow enables you to focus on creation rather than planning.
— Metin
metinseven.com — 3D (print) models • animation • characters • icons • illustration • infographics • visualization
I am not sure that Blender run inside a navigator ? :)
And you are very lucky to be genetically modified for use it! :)
7786.28 In reply to 7786.27
Maybe I'm an old-fashioned guy, but I prefer having a locally installed application in stead of working in an internet browser. I'm also not a fan of the growing subscription virus. I've stopped using Adobe software because of that. For 2D stuff I'm now happy using Affinity Photo, Affinity Designer, Photoscape X and some other tools.
Yes, I can be a grumpy guy, I know. But I do love discovering new tools, like you, Frenchy. :)
— Metin
7786.29 In reply to 7786.28
as you speak about new tool :)
Any place on the earth converted in 3D file obj! :)
http://topotopo.io/
my little try :) (render with the free Simlab Composer Light (maxi 1920 * 1080 )
http://www.simlab-soft.com/3d-products/simlab-composer-freelicensee.php#light
EDITED: 23 Feb 2017 by PILOU
7786.30 In reply to 7786.29
I saw it in your ZBrush Other Software thread. I like such charming toys.
— Metin
Excellent! ;)
EDITED: 27 Jul 2017 by PILOU
7786.34 In reply to 7786.33
Hi Pilou.
...A sort of web version of Rocket3F/NVIL.
It seems the missing link.
For what I've tried so far it's very efficient for a low-poly modelling.
But, honestly, for mid or high poly/SDS meshes it's too slow.
Very slow.
But for strict low-poly/SDS I think it's a very good and funny product.
Bye.
7786.35 In reply to 7786.34
its made for little objects! :)
EDITED: 14 Feb 2019 by PILOU
7786.37 In reply to 7786.36
Yes! It's a wonderful online app :)
Show messages:  1-17  18-37
