Select Duplicate
All  1-3  4-11
If I copy a curve ten times
Select all
Call Removeduplicates nothing arrive!
What I miss ?
7782.5 In reply to 7782.4
Do you mean copied directly in the same spot 10 times, or have you made 10 copies in different positions?
The RemoveDuplicates command will only target exact duplicates, meaning objects that are copies of each other and are in the same position overlapping directly on top of each other.
If your curves are moved copies, they all have different x,y,z coordinate values for their control points and so because they have different data they are not considered to be duplicates as far as this particular command is concerned.
7782.6 In reply to 7782.5
<< have you made 10 copies in different positions?
Yes this! :)
OK this time all works fine when then are exactly overlapsed!
Only one is now surviving! :)
7782.7
Hello all, Michael,
I am bumping this thread up as I find myself often looking for a "select duplicates" command. I am aware of RemoveDuplicates which works great, but being able to just visualize the issue (without deleting) would be very useful too. This command or script would select all overlapping/duplicate curves minus one element of each set. This would allow to not work blind, so to speak - similarly to how 3d programs allow to find duplicate faces/overlapping polygons with a diagnose tool.
I hope this makes sense !
7782.8 In reply to 7782.7
Hi pior, please try the attached script. It should work same as RemoveDuplicates except the curves that would have been removed are selected instead.
7782.9 In reply to 7782.8
So with this new function you must Press Delete for erase them if you are agree with the selection ?
7782.10 In reply to 7782.9
Hi Pilou, yes with this one you can press Delete to remove them, or do other things like hide them or assign a particular style or name to them, etc...
7782.11
Well, this is perfect, and extremely useful. Thanks Michael !
FP : Indeed. Once the culprits are selected, one can then move them around to investigate how many duplicates where created, and so on. This gives great information as to what may have actually happened to cause the duplicates in the first place - whereas a blind, bruteforce cleanup without feedback doesn't let one see that.
EDITED: 4 Sep 2021 by PIOR_O
Show messages: All  1-3  4-11
