Bug w/ Reversed Boolean Operations
All  1  2-5
7779.2 In reply to 7779.1
This randomly fixed itself... not sure if there is anything I can do to record the error conditions if it happens again.
7779.3 In reply to 7779.1
Hi FDP, it probably means the orientation of the object was not correct - that the geometry library had analyzed the object and got the decision wrong about which side was pointing to the outside of the closed volume... It could be due to a bug in the geometry library or problems with the object itself if you have any surfaces in it which fold back over top of themselves in a self-intersecting manner.
Anyway it's likely to be related to the geometry of the particular objects you were using at that moment.
7779.4 In reply to 7779.2
""""""""""""""not sure if there is anything I can do to record the error conditions if it happens again.""""""""""""
Save a 3dm file with the objects/geometry that is failing and attach it here.....
7779.5
Thanks Michael, as always, I appreciate your taking the time to answer my issue!
Unfortunately can't post any files from this project as it is confidential for a client. In years of using MoI this is the first time I have ever had this error happen, but if it ever crops up with a non-confidential project I will share.
Show messages: All  1  2-5
