Pattern generator as guilloché
All  1  2-9
7776.2 In reply to 7776.1
Hi Bob, do you have any sample models or even just illustrations of the type of output you're looking for? That would help a lot to better understand what you're looking for.
Max Smirnov has several different advanced array generation tools which may be of use, they would probably be worth investigating:
Array3D: http://moi3d.com/forum/index.php?webtag=MOI&msg=7574.10 http://moi.maxsm.net/item/47#top
Radial pattern: http://moi.maxsm.net/item/53#top
There are some other array like tools here too:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7574.5
One of the ones from the last link above is "ScriptArray" which is a base script that modifies stepping and rotation for each array instance, and you can edit the script to produce different effects for how the movement and rotation of each step is decided:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5595.18
If you need something that's different from any of the above mechanisms it would probably help to have some examples.
if you are using a Mac, there is an awesome appl for. Let's you also export vector graphics.
http://www.excourse.com/excentro/
I suppose contextfree can do the same :)
http://www.contextfreeart.org/
But you must write ten lines by yourself! ;)
or this one
http://www.hypatiasoft.fr/Folder_KnotsBag/Pages_HTML/KnotsBag_A.html
and of course the last Nodes Editor of MOi! ELEPHANT!
(By Max Smirnov the mad scientist! ;)
Sorry here in French but...very graphic ! Array Circular
You can of course increase the number Max of repetitions! (here 100)
That I love is the ultima simplicty for infinite very complex results! :)
And you can take any thing :3D Point(s), 3D line(s), 3D curve(s), 3D surface(s), 3D volume(s)
EDITED: 14 Dec 2015 by PILOU
7776.5 In reply to 7776.4
Thank you, appreciate ...yes it's exactly the same level of eterations that I need, eccentro goes even further to take a tree out of it and link forms at the top of the tree and affect them with the array you need and also different options through the lines you need.
I will try all and will comeback with some results , wait and see....
Thank you so much.
Bob
7776.6 In reply to 7776.4
Hello Pilou,
http://www.amazon.de/Wenger-Schweizer-Offiziersmesser-Messer-Schatulle/dp/B000R0JDSI
I think we don't Need it anymore:-)
Kind regards
Karsten
7776.7 In reply to 7776.6
Indeed! :)
7776.8
Hello,
If you happen to use CorelDRAW:
http://www.oberonplace.com/products/securidesign/index.htm
It's $15 but it has a trial available to see if it is what you need. I've also found their Curveworks utility to be very useful in cleaning up outlines generated in MoI.
7776.9
Hello,
Also of interest is Inkscape's clone tiling function:
The instructions :
http://tavmjong.free.fr/INKSCAPE/MANUAL/html/Tiles.html
A basic tutorial :
https://www.youtube.com/watch?v=xPGF8rzVKHw
It supports the 17 types of symmetries and you can export to pdf then import into MoI.
Michel
Show messages: All  1  2-9
