Boolean Union problem
All  1-2  3-11
7761.3
Hello twofoot,
Your surfaces are skimming one another in a few instances and you happen to have little surface slivers in other cases which are preventing the surfaces from joining into a solid. In cases where I find surfaces not fitting together I step back and try to see if I can model the solid using more of a different command set. In this case I would use more Boolean operations using curves to prevent the surface skimming sort of issue you're experiencing.
7761.4 In reply to 7761.1
Hi Chris, let me know if you are still stuck after the advice above.
7761.5
Hello,
I can do a short video if you like on the workflow I used to create the solid.
7761.6 In reply to 7761.5
If you don't mind, that would be helpful. Nice render BTW.
Thanks!
Chris
7761.7
Hello,
The model reconstruction video is posted. Runtime is around 20 minutes.
https://vimeo.com/149120260
A sort of MasterClass! ;)
7761.10 In reply to 7761.7
Brilliant. Thank you so much! =)
Chris
7761.11 In reply to 7761.7
I finally had time to watch your entire video. I really cannot thank you enough for the effort you put into making it.
I also learned I have some bad habits when it comes to modeling, and where to look for similar issues going forward.
Best,
Chris
Show messages: All  1-2  3-11
