Help requested: Bending an object
7752.1
Hi!
Sorry if this is in the wrong place, I had some difficulties maneuvering the site and I was unable to find a post adressing my issue.
I am trying to bend an object in one direction using flow.
When I do so, the result is always that the object gets twisted in two directions instead of only the one.
http://i67.tinypic.com/35kvo8m.jpg
Could someone please explain to me how to bend this object as the curve I have drawn.
I seem to be able to do so with a simple 3d rectangle but the item I'm trying to bend keeps twisting.
I only understand the simple basics of this program so I'm sure I'm doing something wrong.
I have been unable to find any examples of others doing the same thing, I have only found examples where
people are teaching vastly more complicated maneuvers wich are way too complex for me to follow.
Thanks!
7752.2 In reply to 7752.1
Nothing special to do! Just take 2 curves aligned vertically above the object!
7752.3 In reply to 7752.1
Hey zim,
Its hard to tell from the screenshot, but i can see a couple rules to follow from it.
The "base" curve should be placed with the object to flow as you want it to end up on the surface. So if you look at frenchys image, his straight curve is laying directly at the base of the object. Yours seems to be situated some distance away? The flow calc will read this distance.
The other is the orientation. It will be best to have things pointed "up" to do the flow...(up being the z axis).
7752.4
aha!
Thanks!
I was not aware of the distances causing the object to distort
(I hadn't gotten far enough to notice that one yet).
I was also not aware it was best to flow with the object lying
down. Thanks.
I then suppose there is something wrong with my object that
causes it to bend in two directions?
I can get a simple shape to bend the way I want but for some
reason this frame seems to refuse to bend only the way I
want it.
http://i64.tinypic.com/2ut50et.jpg
http://i67.tinypic.com/33p8umo.jpg
7752.5 In reply to 7752.4
Try putting your target curve outside of the bounds od the object and base curve.
Attach the 3dm file for better help.
