Using PatterNodes to Create a Speaker Grill Detail
 1-9  10-29  30-49  50-58
7745.30 In reply to 7745.28
@TOM - The HexTesselation macro is a part of the Elephant Node Editor. It is a macro that creates an array of hex objects.
My skills with advanced design graphics is limited. There are many here with talents that are remarkable. They are the ones that write the amazing routines. I just mix them together to see what happens and having fun at the same time.
Wayne
Note: Is the spelling HexTesselation or HexTesselarion? The menu has one and the display cell header has the other spelling. Add it to the list..
EDITED: 17 Jan 2021 by WAYNEHILL5202
7745.31 In reply to 7745.30
Damned!
All that is not in the Native nodes, and in the extensions nodes repository by James!
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
so where is this other one ?
7745.32 In reply to 7745.31
Right click the NE and two selections appear. Node and Macro. Click Macro and the macros appear. Another chapter for your elephant documentation.
wayne
7745.33 In reply to 7745.32
yes but in Macro I have just Create & Import but nothing as existing menus!
7745.34 In reply to 7745.33
I am looking for the source of the advanced macros. They might have been posted in a zip file at a moment in time from a developer and should be considered undocumented and experimental.
Wayne
7745.35 In reply to 7745.34
Thanks by advance!
7745.36 In reply to 7745.30
Noting that the r key is next to the t key on a keyboard:
After google search, Tesselarion appears to be a fairly common misspelling of tesselation :-)
7745.37 In reply to 7745.35
The sub macros are on node files with sub macros. I copy them for later use.
Example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1537
triAxialWeaveSepColors.nod
has a sub macro 'offsetgrid.nod' that is also loaded.
I take the sub macros and copy them to my directory:
C:\Users\Wayne\AppData\Roaming\Moi\nodeeditor\macros
They are used later for different nodes and show up on the macro menu.
Just something I do for learning how things work.
Wayne
A Doyle spiral, with P=14, Q = 28, deleting alternate rays, and reducing circle radii, seems to match the pattern of the grill.
My script/node is on hiatus, due to too much work :-)
Mobius transformation of hex grid might be worth a study...
7745.39 In reply to 7745.28
Tom
I'm not sure that this is exactly what you wanted, but it may be a starting point.
PS >> "Tesselarion" <<
I think that spelling mistake is indeed due to my poor typing!
EDITED: 1 Oct 2019 by JFH
7745.40 In reply to 7745.37
<< The sub macros are on node files with sub macros.
Yes I know that but it's more easy to have yet a little repository from someone like your!
If you have not defence secrecy inside of course! ;)
Ps @ James you have not the same gap between form! ;)
EDITED: 29 Sep 2019 by PILOU
7745.41
Dear gentlemen your tips are very much appreciated - thank you all !
Maybe the only solution will be a manual placement of each object
but I am experimenting with the tools you kindly presented.
7745.42 In reply to 7745.41
Tom
If truly equi-spacing that is paramount, the holes must deviate from regular polygons, like so:
Here is .nod file for generating image above
Hope this helps
EDITED: 29 Apr 2020 by JFH
7745.43
What an amazing node !! - and what kind of brain do you have to put this thing together ?!?!
The idea behind this pattern is for a 2dimensional piece of jewelry which creates the illusion
of 3diemensional space.
I used the nodebased shape to place and resize the singlegem- objects by hand.
Vasarely revival! :)
And another node inside the extention repository (not yet started) :)
7745.45
Vasareli - OpArt, you are right. Incredible node skills, hats off James !
7745.46 In reply to 7745.42
Bellissimo!
7745.47 In reply to 7745.45
Tom & Pilou,
If you think that image above looks like a Victor Vasarely, then have a look at the one I've just posted here: https://www.instagram.com/nodeology/
7745.48 In reply to 7745.47
Just your last image posted was a Vasarely heritage! ;)
and this one...
By James
https://www.instagram.com/p/B3EZGkIJ5oY/
EDITED: 1 Oct 2019 by PILOU
7745.49 In reply to 7745.48
Breathtaking art, James ! How nany different nodes have you developed to
achieve those results ?
Show messages:  1-9  10-29  30-49  50-58
