Using PatterNodes to Create a Speaker Grill Detail
 1-2  3-22  23-42  43-58
7745.23 In reply to 7745.22
Thank you Pilou, I tried it out but nothing happened - I need to take a closer look how this script works.
I am attaching a pattern like the one I want to achieve / create variations.
7745.24 In reply to 7745.23
Maybe "Separe" your result before use Explodemove!
EDITED: 27 Sep 2019 by PILOU
7745.25 In reply to 7745.23
There is a hex pattern on the grill. Used NodeEditor with a modified HexTesselation macro and James's FishEye Node. Not quite right on hole sizing.
EDITED: 17 Jan 2021 by WAYNEHILL5202
A pannel of objects
ExplodeMove
Flow on half sphere ;)
7745.27 In reply to 7745.24
I appreciate your help Pilou, but what if the objects get smaller in size like in the photo shonwn ?
7745.28 In reply to 7745.25
Hi, first time I here about a hextessekation macro, can you tell me where I can find it ?
7745.29 In reply to 7745.27
<<what if the objects get smaller in size like in the photo shonwn?
It works at any size! ;)
The different size smaller is not done by the perspective ?
Else not make an Half line of objects decreasing and an a circular array
EDITED: 28 Sep 2019 by PILOU
7745.30 In reply to 7745.28
@TOM - The HexTesselation macro is a part of the Elephant Node Editor. It is a macro that creates an array of hex objects.
My skills with advanced design graphics is limited. There are many here with talents that are remarkable. They are the ones that write the amazing routines. I just mix them together to see what happens and having fun at the same time.
Wayne
Note: Is the spelling HexTesselation or HexTesselarion? The menu has one and the display cell header has the other spelling. Add it to the list..
7745.31 In reply to 7745.30
Damned!
All that is not in the Native nodes, and in the extensions nodes repository by James!
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
so where is this other one ?
7745.32 In reply to 7745.31
Right click the NE and two selections appear. Node and Macro. Click Macro and the macros appear. Another chapter for your elephant documentation.
wayne
7745.33 In reply to 7745.32
yes but in Macro I have just Create & Import but nothing as existing menus!
7745.34 In reply to 7745.33
I am looking for the source of the advanced macros. They might have been posted in a zip file at a moment in time from a developer and should be considered undocumented and experimental.
Wayne
7745.35 In reply to 7745.34
Thanks by advance!
7745.36 In reply to 7745.30
Noting that the r key is next to the t key on a keyboard:
After google search, Tesselarion appears to be a fairly common misspelling of tesselation :-)
7745.37 In reply to 7745.35
The sub macros are on node files with sub macros. I copy them for later use.
Example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1537
triAxialWeaveSepColors.nod
has a sub macro 'offsetgrid.nod' that is also loaded.
I take the sub macros and copy them to my directory:
C:\Users\Wayne\AppData\Roaming\Moi\nodeeditor\macros
They are used later for different nodes and show up on the macro menu.
Just something I do for learning how things work.
Wayne
A Doyle spiral, with P=14, Q = 28, deleting alternate rays, and reducing circle radii, seems to match the pattern of the grill.
My script/node is on hiatus, due to too much work :-)
Mobius transformation of hex grid might be worth a study...
7745.39 In reply to 7745.28
Tom
I'm not sure that this is exactly what you wanted, but it may be a starting point.
PS >> "Tesselarion" <<
I think that spelling mistake is indeed due to my poor typing!
EDITED: 1 Oct 2019 by JFH
7745.40 In reply to 7745.37
<< The sub macros are on node files with sub macros.
Yes I know that but it's more easy to have yet a little repository from someone like your!
If you have not defence secrecy inside of course! ;)
Ps @ James you have not the same gap between form! ;)
EDITED: 29 Sep 2019 by PILOU
7745.41
Dear gentlemen your tips are very much appreciated - thank you all !
Maybe the only solution will be a manual placement of each object
but I am experimenting with the tools you kindly presented.
7745.42 In reply to 7745.41
Tom
If truly equi-spacing that is paramount, the holes must deviate from regular polygons, like so:
Here is .nod file for generating image above
Hope this helps
EDITED: 29 Apr 2020 by JFH
Show messages:  1-2  3-22  23-42  43-58
