Using PatterNodes to Create a Speaker Grill Detail
 1-14  15-34  35-54  55-58
Rolling wheels! :)
7745.16
Excellent script, as usual.
Thanks a lot MAX.
Mik
7745.17
bugfix update
v.1.3
7745.18 In reply to 7745.17
7745.19
Max Smirnov,
Thank you for the free use of your many scripts, especially the RadialPattern script!
I salute your generosity and hope that good fortunes will soon offer me an enhanced capacity to reciprocate.
Regards,
-- Mindset
EDITED: 26 Jan 2017 by IGNITER
Flashy!
7745.21
In search for a solution for a pattern design I came across this great script.
My question is : I need equidistant gaps between the multiplied objects -
is this achievable wit this script ?
Or achievable by other means ?
Best TOM
7745.22 In reply to 7745.21
I don't know what is the nature of your object result but if you press Tab then write ExplodeMove (without space) maybe you will have your result wanted! ;)
Explode Move is hidden function but integrated inside the Native Moi3D !
Else you can recreate all the plugin PatterNodes or what anything you want exactly with ELEPHANT! ;)
http://moiscript.weebly.com/biblio-elephant.html
EDITED: 27 Sep 2019 by PILOU
7745.23 In reply to 7745.22
Thank you Pilou, I tried it out but nothing happened - I need to take a closer look how this script works.
I am attaching a pattern like the one I want to achieve / create variations.
7745.24 In reply to 7745.23
Maybe "Separe" your result before use Explodemove!
7745.25 In reply to 7745.23
There is a hex pattern on the grill. Used NodeEditor with a modified HexTesselation macro and James's FishEye Node. Not quite right on hole sizing.
EDITED: 17 Jan 2021 by WAYNEHILL5202
A pannel of objects
ExplodeMove
Flow on half sphere ;)
7745.27 In reply to 7745.24
I appreciate your help Pilou, but what if the objects get smaller in size like in the photo shonwn ?
7745.28 In reply to 7745.25
Hi, first time I here about a hextessekation macro, can you tell me where I can find it ?
7745.29 In reply to 7745.27
<<what if the objects get smaller in size like in the photo shonwn?
It works at any size! ;)
The different size smaller is not done by the perspective ?
Else not make an Half line of objects decreasing and an a circular array
EDITED: 28 Sep 2019 by PILOU
7745.30 In reply to 7745.28
@TOM - The HexTesselation macro is a part of the Elephant Node Editor. It is a macro that creates an array of hex objects.
My skills with advanced design graphics is limited. There are many here with talents that are remarkable. They are the ones that write the amazing routines. I just mix them together to see what happens and having fun at the same time.
Wayne
Note: Is the spelling HexTesselation or HexTesselarion? The menu has one and the display cell header has the other spelling. Add it to the list..
7745.31 In reply to 7745.30
Damned!
All that is not in the Native nodes, and in the extensions nodes repository by James!
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
so where is this other one ?
7745.32 In reply to 7745.31
Right click the NE and two selections appear. Node and Macro. Click Macro and the macros appear. Another chapter for your elephant documentation.
wayne
7745.33 In reply to 7745.32
yes but in Macro I have just Create & Import but nothing as existing menus!
7745.34 In reply to 7745.33
I am looking for the source of the advanced macros. They might have been posted in a zip file at a moment in time from a developer and should be considered undocumented and experimental.
Wayne
Show messages:  1-14  15-34  35-54  55-58
